Tebe sa clovek nezavdaci ... http://www.zslip.com/ ... tam budu app pre ATI pod MilkywayGPU.gabberattack napísal:slavko.sk napísal:A to je chyba lebo by si sa docital toto:gabberattack napísal:no teraz som na Milkty uplne zanevrel.
CUDA Update -- Working Compile Script
May 22, 2009
I've updated v0.04 to the code release directory. This should work correctly with the compile script. The next steps on our to-do list are getting checkpointing working correctly for it (i'm pretty sure its not working), and compile time specified single or double floating point precision. In the next couple days I should get the milkyway_gpu forums up and running and some test work units available.
CUDA Update
May 22, 2009
I updated another version of the GPU code. It should have the evaluation directory now.
CUDA Release v0.02
May 21, 2009
I missed a couple files in the previous release, so theres a v0.02 in the code release directory now.
CUDA Application Alpha Release
May 21, 2009
I've released a preliminary version of the CUDA application in the code release directory. For more detail, there's a forum post here. This should run on the same test samples, however I'm having some issues getting a working makefile/build script using both BOINC and the CUDA libraries, so if anyone has some knowledge about how to do this it would be really appreciated.
CUDA Application Update
May 20, 2009
Looks like I've finally gotten the CUDA application working. I'm in the process of cleaning up the code, and it should be available for you to play around with tonight. It's my first crack at a CUDA application, so it's a bit rough, but currently it's crunching the current stripe 82 WUs in around a minute using a GeForce 9600M GT. I'm sure there's quite a bit more optimization we can to do get it running even faster, as this is the first version and not optimized at all. Part of the reason this has taken so long was that I was doing quite a bit of testing comparing double and single precision math on the GPU. I've come up with some schemes that will allow us to use older graphics cards which don't support double precision math (like the GeForce I've been using); which should let a lot more of our users be able to use the GPU application. More news later when I post the code.
--Travis
Ja mam ATI grafiku, takze CUDA mi je uplne naprd.
CUDA je podporovana priamo BOINC Managerom - to pojde ako default tak ako ine GPU podporovane projekty, ATI nie je ale cez app_info.xml sa to tam bude dat narvat.
