Coll. na GPU0 a Milky na GPU1 ???
Príspevokod užívateľa Kiwi » Pi Sep 24, 2010 9:51 pm
Ako nastavit, aby Coll. pocitalo na 1. GPU a Milky na 2. ?
Exclusion of GPUs: x (default none)
If a certain GPU should not be used by the app, one can exclude it. The GPU number has to be in
the range 0..31. The first GPU in the system has the number 0. This option can be used multiple
times. Per default, all supported ATI GPUs are used. Do not use it with an ATI aware BOINC client!
It should be ignored in that case. But there may be some unwanted side effects.
Example:
<cmdline>x1 x2</cmdline>
The app will not use the second and the third GPU in the system.
