Prosim o radu. Ked sa mi vypne pocitac, napr. po vypadku
prudu, tak mi nabehne login do linuxu a az po lognuti
spustam manualne klient.
Chcel by som, aby sa mi klient spustal ako daemon
v spustacich skriptoch v /etc/init.d
Pouzil som rozne scripty, ktore som vygooglil,
ale ani jeden nefungoval po upravach na moj
system adresarov a uzivatelov. Ale ani jeden
sa mi nepodarilo spustit ani z terminalu.
Tak som urobil vlastny:
#!/bin/sh
BOINC_DIR=/home/xxx/BOINC
BOINC_USER=xxx
BOINC_LOGFILE=/var/log/boinc_log.log
BOINC_BIN=$BOINC_DIR/boinc
test -x $BOINC_BIN || { echo "$BOINC_BIN not installed";
if [ "$1" = "stop" ]; then exit 0;
else exit 5; fi; }
# Check for exist
. /lib/lsb/init-functions
case "$1" in
start)
echo -n "Starting"
cd $BOINC_DIR
#chown $BOINC_USER $BOINC_LOGFILE
/sbin/start-stop-daemon --start --nicelevel 19 --startas $BOINC_BIN --user $BOINC_USER --chdir $BOINC_DIR --background --pidfile /var/run/boinc.pid -- -daemon -redirectio -insecure
#startproc -u $BOINC_USER -l $BOINC_LOGFILE -s $BOINC_BIN -dir $BOINC_DIR
stop)
echo -n "Shutting down boinc "
## Stop daemon with killproc(8) and if this fails
/sbin/start-stop-daemon --stop --exec $BOINC_BIN --user $BOINC_USER --signal 9
try-restart|condrestart)
## Do a restart only if the service was active before.
## Note: try-restart is now part of LSB (as of 1.9).
## RH has a similar command named condrestart.
if test "$1" = "condrestart"; then
echo "${attn} Use try-restart ${done}(LSB)${attn} rather than condrestart ${warn}(RH)${norm}"
fi
restart)
$0 stop
$0 start
force-reload)
$0 try-restart
reload)
status)
echo -n "Checking for service boinc "
checkproc $BOINC_BIN
echo "Usage: $0 {start|stop|status|try-restart|restart|force-reload|reload}"
exit 1
esac
exit 0
Ten mi spusti korektne klienta s prikazovaho riadka.
Ale ak ho dam do /etc/init.d, zmenim vlastnika
na root, prava na 755 a urobil symbolic link
v /etc/rc4.d/S99boinc na script v /etc/init.d,
tak ho ako daemona nespusti.
Vie mi niekto poradit, kde robim chybu ?
Dik.
spustenie boinc klienta ako daemona
Naposledy upravil/-a Kiwi v Pi Aug 24, 2007 9:33 pm, upravené celkom 1 krát.
a run level 4 je ok? ine skripty z /etc/rc4.d/ sa spustaju?
Co to je za linux? Niektore nemaju run lvel 4 alebo je to multiuser s gui, ak nespustas gui tak mozno run level 3 by bol lepsi.
daj si do toho startovacieho skriptu touch na nejaky fajl alebo vypisy do fojlu ci to spusti.
nic ine ma nenapada.
Uz mam riesenie. Do /etc/rc0.d a /etc/rc1.d a /etc/rc6.d
treba dat symbolicke linky napr. K17boinc,
tie sluzia na poslanie shutdown signalu
a do /etc/rc2.d, /etc/rc3.d /etc/rc4.d a /etc/rc5.d
treba dat symbolicke linky napr. S17boinc,
na file /etc/init.d/boinc, samozrejme musi
mat executable flag.
Takze, ak mi vypadne elektrina, uz nepridem
a cenne sekundy
a cenne sekundy
Zalezi na tom, aku mas distribuciu, podla toho treba davat run-levely... ale vacsinou su levely 0, 1 a 6 na stop a 2, 3, 4, 5 na start.
Ja mam stareho dobreho Debiana a tam je spickovy update-rc.d, ktory vytvara symbolicke linky (a este je aj trocha blbovzdorny, ak uz nejake linky na dany init-script su)... v Ubuntu by to teda malo byt tiez...
A inak v Debiane som si nainstaloval balik boinc-client, kde uz bol aj init-script aj linky do /etc/rc*.d a myslim ze aj vytvoril user/group boinc... V stable distribucii bol boinc balik sice obstarozny, ale to som downloadol novsi rovno z boinc, dal do ineho adresara a potom len v konfiguraku zmenil cestu k binarke klienta. Cize teraz vyuzivam init-script z balika ale boinc-client binarku mam vlastnu (a tu priebezne updatujem).
