Stav projektu
Stav projektu
Migracia uspesne pokracuje. Trva to o nieco dlhsie ako povodne novi admini predpokladali, je to sposobene tym, ze sa snazia odstranit vsetky existujuce problemy. Migracia by mala byt ukoncena do konca Februara.
Viac na http://lhcathome.cern.ch.
Zoznam veci ktore maju v plane na projekte este urobit / vyriesit:
* Zalohovanie a obnova databazy
* Zalohovanie servra
* Dokoncit testovaci system
* Najst, skompilovat a otestovat casti servra:
- Transitioner
- Validator
- Assimilator
- File deleter
* Overenie funkcnosti mailera
* Skusobna migracia
* Skutocna migracia
* Vyriesenie akehokolvek problemu ktory sa vyskytne!
S pozdravom,
Neasan and Alex.
- Transitioner
- Validator
- Assimilator
- File deleter
* Skusobna migracia
* Skutocna migracia
S pozdravom,
Neasan and Alex.
Migracia pokracuje pomalsie ako sa povodne ocakavalo, takze este par tyzdnov potrva kym sa vsetko stabilizuje a znovu budeme moct pocitat.
Aktualne ulohy:
Aktualne ulohy:
- Zacat s prenosom databazy
- Spojazdnit system s novou databazou
- Uistit sa ze e-mail funguje (zlozitejsie ako sa na prvy pohlad zda
) - Otestovat prenos dat
- Preniest data (naostro)
- (hmm, ako spravne prelozit toto: Sort out job submission over AFS by SixTrack User) Vyriesit odovzdavanie prace Six Track uzivatelom (aplikaciou?) cez the Andrew File System
Nieco nove o stave projektu:
Server Status
Up, out of work
301 workunits in progress
43 concurrent connections
14.05.2007 14:00 BST
At the time of writing there are approx 300 workunits in progress. When this figure reaches zero the lhcathome service will be migrated from the server at CERN to the server at Queen Mary, University of London. Hopefully this will be tomorrow Tuesday 15th May.
Server Status
Up, out of work
Migracia do UK
Podla najnovsich informacii by sa migracia z CERN-u do Queen Mary mala uskutocnit v pondelok 21. maja.
Dufajme ze to uz konecne rozbehnu
LHC@home:
16.05.2007 14:40 BST
OK so we are down to zero workunits in progress, however it's late in the day and I'm at a meeting now till Monday. So looks like Monday 21st is migration day!
How to migrate:
The idea is that to migrate you will have to do nothing!
Techincally we will change the cern.ch DNS entry to point to an IP address in the Queen Mary, University of London network (138.37.0.0/16).
The rest should then fall into place!
Alex Owen
LHC@Home server admin
LHC@home:
How to migrate:
Alex Owen
Projekt by mal byt zacat ozivovany buduci tyzden, migracia je dokoncena. Mali by sa dat aj pripajat nove kompy a buduci tyzden uvolnia WU. Viac na http://www.boinc.sk.
Re: Stav projektu
We should have a load of work next week.
This coincides nicely with the actual start of the LHC which this project has helped build.
Mimochodem, drzel bych se narozu lidi z projektu ohledne toho, co je skutecnym spustenim LHC a ne nazorem foresta.
