cavte chalani
mam takyto problem - nainstaloval som brachovi na dualcore windows vista basic - nainstaloval boinca - spustil projekt - a doinstaloval par programov pri ktorych som musel restartnut a pri nabehnuti visty mi hodil windows defender boinca ako nezelany soft a nespustil ho - neviete ako mam zadat defenderu aby ho bral ako normalny program??
skusal som jeho nastavenia ale neislo mi to - pomoze preskenovanie celeho kompu defenderom?
dakujem
boinc na windows vista basic
Re: boinc na windows vista basic
Odinstaluj Windows vista basic, nainstaluj Windows XP, nainstaluj Boinca, hotovo.horvy napísal:cavte chalani
dakujem
A teraz vazne:
Windows Vista je pekne pokafrany soft, mal som s nim tiez tazkosti, ked som sa snazil instalnut BOINCa, doteraz vyvolava sem-tam crash na kompe. Toto pise Wikipedia:
Windows Vista specific functionality
Windows Defender in Windows Vista automatically blocks all startup items that require administrator privileges to run (this is considered a bad behaviour for a startup item). There is no known easy way to automatically unblock these items, the only suggestion given is to "contact the software vendor for an updated version" which is Vista compatible (does not require administrator privileges to run). This automatic blocking is related to the UAC (User Account Control) functionality in Windows Vista, and requires the user to manually run each of these startup items each time they log in. It is possible to circumvent this behavior by adding the item to the Task Scheduler (with "Run with highest privileges" checked and with "at log on" as a trigger) and removing the startup item.
Preklad poslednej vety:
Je mozne obist toto spravanie tym, ze das polozku do Task Schedulera (tento vyraz neprelozim, ani keby som sa one) /pricom je nastavena polozka "spustit s najvyssou prioritou a takisto oznacene spustenie pri prihlaseni/ a odstranenim Startup polozky (ktoru tam mas predpokladam).
P.S.: Skusal si samoinstalacny balicek, ktore je niekde na BOINC.CZ ? Honza tu daval link na fore v niektorom threade, ale uz nepamatam kde. Inak /pre SLAVKA, alebo MEXXa/ - hodilo by sa dat ten balicek do polozky "Stiahnite si" na BOINC.SK, je to velmi uzitocny balicek. Mozno to Ti poriesi problem, spustis tam dva .reg subory a malo by sa to nakopnut pri spusteni systemu a nie az pri nalogovani uzivatela (mozno to tak obide aj dementny Defender.
