Error 417
Error 417
hojte,
neviem si rady s tymto errorom, po hladani som nasiel riesenie cc_config.xml -ka, lenze toto mi nezabera. pouzivam portable verziu boinc, je mozne, ze na proxy je bloknuty port, na akom to komunikuje?
Re: Error 417
Zo serverom to komunikuje normalne HTTP port 80 pokial nenastavis proxy a iny port.
Teda ak si sa pytal na komunikaciu klient - projektovy server (scheduler).
Re: Error 417
no cim dalej zacinam mat pocit, ze nase interne IT oddelenie mi bloklo spojenie
2jadrovy 3gigahertz tak ostava nevyuzity... kazdy napad na oje*kanie ocenim
Re: Error 417
Ak si za firemnym proxy, do manazera si nastav uplne rovnaky nazov proxy (adresu) a jeho port ako mas pre internetový prehliadač.
Naposledy upravil/-a marpes v Št Júl 23, 2009 11:09 am, upravené celkom 1 krát.
Re: Error 417
Ja som to tiez riesil a pokial nema clovek adminsky pristup, tak to nespravi.
The BOINC daemon uses port 80 (http) for communications between the host and project server. With 5.1.x http will be joined by https.
The BOINC Manager uses ports 1043 and 31416 for communications with the BOINC daemon. 1043 is the primary port (registered) and 31416 is the fallback (not registered).
BOINC.exe (the daemon) must be allowed to act as a server on ports 1043 and 31416, and also access the internet on port 80 (and whatever https is). The usual problem is that there is a personal firewall that is being overzealous.
Re: Error 417
Pokial z tej masiny mozes browsovat musi bezat aj BOINC.dango napísal:no cim dalej zacinam mat pocit, ze nase interne IT oddelenie mi bloklo spojenie2jadrovy 3gigahertz tak ostava nevyuzity... kazdy napad na oje*kanie ocenim
Re: Error 417
To nemusi vzdy byt pravda. Niektore softverove firewally maju povoleny outgoing access len pre konkretne binarky (niekedy je to len hlupo na meno firefox.exe, ale byva to aj na checksum binarky) a vsetko ostatne je odmietnute... Ma to aj svoj vyznam, napriklad aby nejaky zlomyselny program nemohol "volat domov"...slavko.sk napísal:Pokial z tej masiny mozes browsovat musi bezat aj BOINC.
Re: Error 417
je to tak. v prehliadaci aj boinc mgr mam nastavene to iste proxy (a jedine firemne), browsovanie v pohode, ani s boincom nebol problem. len ked som odisiel na dovolenku a potom po par dnoch si pozrel na strankach projektu, ze "ako sa mi dari", tak tasky boli vyprsane... 2 mozne alternativy, bud mi lahol pc alebo bloknute spojenie. pc bezi a v boinc mgr je error 417
Re: Error 417
... a skusal si resetnut projekt? (o ktory projekt sa jedna?)
Re: Error 417
jasne, to som spravil ako prve. primegrid, malariacontrol, rosetta a este nejake, co som spustal iba sporadicky...
Re: Error 417
Re: Error 417
ak nepomoze odinstalovat BOINC a znova nainstalovat, potom uz Ti moze pomoct iba znalec miestnej siete a jej nastaveni. Zial aj ja chodim s niektorymi strojmi spoza proxy, ale nic ine Ti poradit neviem.
.... a este sa pozri do nastavenia firewall, ci tam mas povolene nieco od boinc....
Re: Error 417
Este ma napadlo, ze mohli vo firme nejako zmenit proxy, prave kym si bol na dovolenke... proxy autorizacii je totiz niekolko typov a browsery vacsinou vedia robit so vsetkymi, ale BOINC celkom nie. V helpe WCG je popisane, ako zistit, aky typ proxaca mas... Treba zapnut debugovacie flagy a z vystupu vycitat typ a potom ten typ natvrdo nastavit. Sam som to musel vo firme pouzit, inak mi neslo WCG...
V kazdom pripade, debug flagy v cc_config.xml mozu pomoct vypisat viac detailov o problemoch so spojenim...
Re: Error 417
dik, zajtra skusim. je to dost mozne, ze je zmeneny typ proxy. skusim to debugovat, ci sa nieco rozumnejsie dozviem.
Re: Error 417
takze teraz zahada
skusil som si pridat project world comunity grid - clean energy a vsetko slape, ako ma. primegrid a malaria mi stale vypisuju error 417, takze s tym nasim zmenenym firemnym proxy to asi nebude. ale uz mam pokojnejsie srdce, ze to ide
skoda, ze nie moje oblubene projekty (zatial)
