Stav projektu
Stav projektu
News
March 5, 2007
This week our servers are being patched to include the new Daylight Savings Time schedule. Certain services (web sites, data transfers, etc.) may by off-line for short periods.
Tento tyzden budu obcasne vypadky webovych stranok, datovych prenosov a pod. z dovodu instalovania novych zaplat na servery Seti@home.
March 5, 2007
- Zerkof12
z fora od Matt Lebofsky : "splitters were still unable to gather resources to create enough work to send out" prelozene - nie je dostatok jednotiek na spracovanie, lebo splittery idu na Solarise a idu uplne naplno a na prechode na Linux sa pracuje a nie je to jednoduche, oi vacsina serverov je na 100 Mbit linkach, co tiez nestaci...
"I'm frustrated - can't sit by my computer anymore" - pise este Matt
zda sa, ze projekt je dlhodobo vo faze znacnych problemov..., takze drzime palce Mattovi a celemu teamu S@H a my crunchujeme o zivot dalej (ak mame co)
sux...
sux...
- Zerkof12
"Mayday! Mayday!" At 4:43 (PDT) this morning, our science database machine, thumper, became hasenfeffer. It currently refuses to acknowledge that it has any disk drives. Since the controllers are attached to the motherboard, major repairs will probably be required. No work can be created until this machine gets fixed.
toto asi nie je treba prekladat, jeden z najdolezitejsich serverov je v pr... a bez neho budeme akosi bez prace ...
- Zerkof12
V pondelok poobede bude novy SUN server, takze snad najneskor v utorok budeme UP, dufam
Vacsina mojej farmy bude v pondelok out of work, takze dufam, ze all bude OK najneskor v utorok...
Tomu sa vravi nacasovanie, len este neviem ci blbe alebo perfektne
- Zerkof12
Snad posledne hlasenie nepriazniveho stavu:
Novy server bude az v utorok (oi v utorok je pravidelna udrzba) a Matt vravel, ze s obrovskou davkou stastia bude SH "funkcne" v stredu... teda dajme si rezervu - asi az vo stvrtok...
(co uz bude cela moja farma out
- Zerkof12
Nepotesim ta... SH este nejde... to bola asi iba nejaka zatulana jednotka, ktora nebola vyratana v deadline a preto ju servery poslali este raz na vyratanie inym ludom s novym deadline, takychto jednotiek je vsak iba cca 10/minutu (alebo hodinu?, teraz neviem...)
- Marek5
- Dátum registrácie: So Apr 21, 2007 6:26 pm
Servery som videl ten je stále out aje aj ostatné sčervenaly
atoto bolo v správach aspom niečo možem rátať.
8.5.2007 17:20:37|SETI@home|Using the wrong URL can cause problems in some cases.
8.5.2007 17:20:37|SETI@home|When convenient, detach this project, then reattach to http://setiathome.berkeley.edu/
8.5.2007 17:20:37|SETI@home|Deferring communication for 11 sec
8.5.2007 17:20:37|SETI@home|Reason: requested by project
8.5.2007 17:20:39|SETI@home|[file_xfer] Started download of file 26se04aa.20755.7888.259654.3.12
8.5.2007 17:20:45|SETI@home|[file_xfer] Finished download of file 26se04aa.20755.7888.259654.3.12
- Zerkof12
V tychto dnoch sa moze stat kadeco, aj stiahnut jednotka, aj blbe hlaska o neexistencii projektu co ratas. Ak by chybove hlasky pokracovali aj po spusteni SH, nechaj dopocitat WU co mas staihnute a resetuj projekt, pripadne detachni a attachni...
